楼主: strive
[T50表头] 加拿大 XT 20-3 数控线性可调电源
发表于 2011-10-17 13:17 | 显示全部楼层
是不是从浙江临海市淘的
 楼主| 发表于 2011-10-17 14:07 | 显示全部楼层
回复 31# zml128h
    矿坛弄的!
发表于 2011-10-17 22:29 | 显示全部楼层
应该是卖家在浙江临海市
发表于 2011-10-18 20:19 | 显示全部楼层
很迷惑,线性电源么,用这么复杂,简直超过可调基准源了!
 楼主| 发表于 2011-10-18 21:00 | 显示全部楼层
回复 34# caiyongzhi
这个俺就不知了!
发表于 2011-10-18 22:24 | 显示全部楼层
俺也想知道价格。PM个价格看看
发表于 2011-10-18 22:43 | 显示全部楼层
XANTREX    XT20-3,   20V---3A 线性     350元/台
1。带GPIB接口
2。电位器采用SPECTROL世界名牌多圈电位器
3。基准采用1N825A。  6.2V,温飘0.002% 。C
4。两个独立的CPU,MC68HC11F;两个独立的温补8MHz晶振
5。NATIONAL      GPIB芯片
6。2N6059达林顿三极管作为电源调整管
7。每台送输出线一条。
发表于 2011-10-18 22:45 | 显示全部楼层
Caracteristicas
XT provides 60 watts of programmable linear DC power in a quarter-rack package. With seven models to choose from, XT is the smart choice for both benchtop and system applications where up to 60 watts of programmable, clean DC power is required. XT is also ideal for OEM applications where a wide adjustment of output voltage or current is required for up to 60 watts in a compact package.
XT is a preferred source for system development and test. It is available in singles, duals, triples and quads in a single package for benchtop use. For systems applications, multiple units can also be rack mounted in one to four unit configurations for up to four independent 60–watt outputs. XT can also be combined in a rack with the 300–watt HPD or 500–watt XPD.
Features
Seven models
Very low noise and ripple
Excellent line/load regulation
Fast transient response
Constant voltage or constant current mode, automatic crossover and mode indication
Current limit
Front and rear outputs standard
Optional internal analog programming includes OVP
Optional internal 16-bit GPIB (IEEE 488) and RS-232 control
LabWindows ® drivers
Remote sense
CE, CSA approvals
 楼主| 发表于 2011-10-18 23:01 | 显示全部楼层
回复 38# wp0527
    谢谢兄弟把资料弄来!!!
发表于 2011-10-19 08:47 | 显示全部楼层
矿坛看到很多,东西不错,就是电压电流小了点,没兴趣...
GMT+8, 2024-5-17 11:29 , Processed in 0.057528 second(s), 30 queries , Gzip On.
