查看: 5474|回复: 12
[其他综合] 分享智能充电器原理图及程序(来自互联网)
发表于 2013-4-9 16:07 | 显示全部楼层 |阅读模式
主程序:
  1. #include <reg52.h>
  2. #include <lcd12864.h>//lcd12864相关控制
  3. #include <DS18B20.h>
  4. #include <math.h>
  5. sbit CTRL_UP=P2^0;
  6. sbit CTRL_DOWN=P2^1;
  7. sbit ADCOE=P2^6;
  8. sbit ADCSTART=P2^7;
  9. sbit ADCALE=P2^5;
  10. sbit ADCA=P2^4;
  11. sbit ADCB=P2^3;
  12. sbit POWERKK=P1^4;
  13. #define ADCDATE P0
  14. sbit KEY1=P3^7;
  15. sbit KEY2=P3^5;
  16. sbit KEY3=P3^6;
  17. void InitSys();//初始化系统
  18. void InitInt();//初始化外部中断
  19. void InitTimer();//初始化定时器,串口中断
  20. void SendSerialData();//启动并发送一组串口数据
  21. void StartADC();//选择通道n,开始转换
  22. void ShowAllTime();//显示完整的时间
  23. unsigned char g_myPar[15],g_CurSend;
  24. //g_t10,g_t11,g_t20,g_t21,g_t30,g_t31,g_n,g_U0,g_U1p,g_U1f,g_U2,g_U3,g_Th,g_Tm,g_Ts;参数顺序
  25. bit bSerialSending;
  26. unsigned char g_time[6];
  27. unsigned char g_CurIn;
  28. unsigned char code g_adda[]={0,1,1,0,1};
  29. unsigned char code g_addb[]={1,0,0,0,1};
  30. unsigned char code g_ctrlu[]={1,1,1,0,0};
  31. unsigned char code g_ctrld[]={0,1,0,1,1};
  32. unsigned char g_tt10,g_tt11,g_tt20,g_tt21,g_tt30,g_tt31;
  33. unsigned char CutState;
  34. bit CurTR0,Curctrlu,Curctrld;
  35. float SqrtDuty;
  36. unsigned char g_Percent;
  37. void main()
  38. {
  39. //DelayMs(10);
  40. //Delay4us(10);
  41. InitSys();
  42. DelayMs(1200);
  43. InitLCD();
  44. InitLCDshow(0);
  45. InitInt();//初始化外部中断0
  46. InitTimer();//初始化定时器0,串口中断
  47. bSerialSending = 0;
  48. //     bLinking = 0;
  49. //WriteLCD(0,0x80);
  50. //DspNumber(123);
  51. StartADC();
  52. while(1)
  53. {
  54. if(KEY1==0)//充电
  55. {
  56. TR1 = 0;
  57. CutState = 0;
  58. POWERKK = 1;
  59. InitLCDshow(0);
  60. TR0 = 1;
  61. g_myPar[0]=g_tt10;
  62. g_myPar[1]=g_tt11;
  63. g_myPar[2]=g_tt20;
  64. g_myPar[3]=g_tt21;
  65. g_myPar[4]=g_tt10;
  66. g_myPar[5]=g_tt11;
  67. //SqrtDuty = sqrt((float)g_myPar[1]/(g_myPar[0]+g_myPar[1]));
  68. //Duty=g_myPar[0]*100/(g_myPar[0]+g_myPar[1]);
  69. TR1 = 1;
  70. StartADC();
  71. ShowAllTime();
  72. DelayMs(100);
  73. }
  74. else if(KEY2==0)//放电
  75. {
  76. TR1 = 0;
  77. CutState = 1;
  78. POWERKK = 1;
  79. InitLCDshow(1);
  80. TR0 = 0;
  81. g_CurIn = 0;
  82. CTRL_UP = 1;
  83. CTRL_DOWN = 0;
  84. TR1 = 1;
  85. StartADC();
  86. ShowAllTime();
  87. DelayMs(100);
  88. }
  89. else if(KEY3==0)//维护
  90. {
  91. TR1 = 0;
  92. POWERKK = 0;
  93. CutState = 2;
  94. InitLCDshow(2);
  95. TR0 = 1;
  96. g_myPar[0]=0xff;
  97. g_myPar[1]=0xf0;
  98. g_myPar[2]=0xfe;
  99. g_myPar[3]=0x74;
  100. g_myPar[4]=0xff;
  101. g_myPar[5]=0xf2;
  102. //SqrtDuty = sqrt((float)g_myPar[1]/(g_myPar[0]+g_myPar[1]));
  103. //Duty=g_myPar[0]*100/(g_myPar[0]+g_myPar[1]);
  104. TR1 = 1;
  105. StartADC();
  106. ShowAllTime();
  107. DelayMs(100);
  108. }
  109. }
  110. }
  111. //初始化系统
  112. void InitSys()
  113. {
  114. unsigned char i;
  115. for(i=0;i<6;i++)
  116. {
  117. g_time[i] =;
  118. }
  119. ADCOE = 1;
  120. ADCALE = 0;
  121. ADCSTART = 0;
  122. POWERKK = 1;
  123. g_myPar[0]=0xff;//0x30
  124. g_myPar[1]=0x30;
  125. g_myPar[2]=0xff;
  126. g_myPar[3]=0x30;//0x30
  127. g_myPar[4]=0xff;
  128. g_myPar[5]=0x30;
  129. g_tt10 = 0xff;
  130. g_tt11 = 0x30;
  131. g_tt20 = 0xff;
  132. g_tt21 = 0x30;
  133. /*g_myPar[0] = 0x80;//g_TH1
  134. g_myPar[1] = 0x00;//g_TH2
  135. g_myPar[2] = 0x00;//g_TH3*/
  136. g_myPar[6] = 6;
  137. SqrtDuty = sqrt(0.5);
  138. //Duty=g_myPar[0]*100/(g_myPar[0]+g_myPar[1]);
  139. }
  140. //初始化外部中断
  141. void InitInt()
  142. {
  143. IT0 = 1;// 0/1 低电平/下跳变
  144. PX0 = 1;// 中断优先级
  145. //EX0 = 1;
  146. //EA = 1;
  147. }
  148. //初始化定时器,串口中断
  149. void InitTimer()
  150. {
  151. TMOD = 0x11;// 使用高4位 0/1/2/3  13位/16位/8位自动重载/双8位
  152. TH0 = (65536 - 49235) / 256;
  153. TL0 = (65536 - 49235) % 256;
  154. PT0 = 1;
  155. TR0 = 1;//开启定时器0
  156. ET0 = 1;
  157. TH1 = (65536 - 49235) / 256;
  158. TL1 = (65536 - 49235) % 256;
  159. TR1 = 1;//开启定时器1
  160. ET1 = 1;
  161. TCLK=1;
  162. RCLK=1;
  163. TH2=0xFF;  //19200bps  22.1184MHz的时钟频率
  164. TL2=0xDC;
  165. RCAP2H=0xFF;  //方式1和方式3的波特率=fosc/(32-(65535-(RCAP2H,RCAP2L))
  166. RCAP2L=0xDC;
  167. TR2=1;
  168. //ET2=1;
  169. SCON = 0x50;//串口方式1,允许接收
  170. PCON = 0x00;//关闭波特率加倍
  171. PS = 1;//设置串口中断为高优先级
  172. ES = 1;//开串口中断
  173. //TH1 = 0xfd;//串口通信使用定时器1,设定波特率9600
  174. //TH1 = 0xf3;//串口通信使用定时器1,设定波特率2400
  175. EA = 1;
  176. }
  177. //开始发送串口数据
  178. void SendSerialData()
  179. {
  180. if(!bSerialSending)
  181. {
  182. bSerialSending = 1;
  183. g_CurSend = 0;
  184. SBUF = g_myPar[g_CurSend];
  185. g_CurSend++;
  186. }
  187. }
  188. //开始ADC转换
  189. void StartADC()
  190. {
  191. CurTR0 = TR0;
  192. TR0 = 0;
  193. g_CurIn=0;
  194. ADCA = g_adda[g_CurIn];
  195. ADCB = g_addb[g_CurIn];
  196. CTRL_UP = g_ctrlu[g_CurIn];
  197. CTRL_DOWN = g_ctrld[g_CurIn];
  198. Curctrlu = CTRL_UP;
  199. Curctrld = CTRL_DOWN;
  200. ADCALE = 1;
  201. ADCALE = 0;
  202. ADCSTART = 1;
  203. ADCSTART = 0;
  204. EX0 = 1;
  205. }
  206. //倒序转换
  207. unsigned char Reverse(unsigned char num)
  208. {
  209. unsigned char i,rtTmp;
  210. rtTmp = 0x00;
  211. for(i=0; i<8; i++)
  212. {
  213. rtTmp <<=1;
  214. rtTmp |= num & 0x01;
  215. num >>= 1;
  216. }
  217. return rtTmp;
  218. }
  219. //显示完整的时间
  220. void ShowAllTime()
  221. {
  222. WriteLCD(0,0x98+4);
  223. WriteLCD(1,g_time[0]);//时
  224. WriteLCD(1,g_time[1]);
  225. WriteLCD(1,:);
  226. WriteLCD(1,g_time[2]);//分
  227. WriteLCD(1,g_time[3]);
  228. WriteLCD(1,:);
  229. WriteLCD(1,g_time[4]);
  230. WriteLCD(1,g_time[5]);
  231. }
  232. //外部中断0服务程序
  233. void Int0() interrupt 0
  234. {
  235. g_myPar[7+g_CurIn] = ADCDATE;
  236. g_CurIn++;
  237. if(g_CurIn<5)
  238. {
  239. ADCA = g_adda[g_CurIn];
  240. ADCB = g_addb[g_CurIn];
  241. CTRL_UP = g_ctrlu[g_CurIn];
  242. CTRL_DOWN = g_ctrld[g_CurIn];
  243. ADCALE = 1;
  244. ADCALE = 0;
  245. ADCSTART = 1;
  246. ADCSTART = 0;
  247. }
  248. else
  249. {
  250. TR0 = CurTR0;
  251. EX0 = 0;
  252. CTRL_UP = Curctrlu;
  253. CTRL_DOWN = Curctrld;
  254. }
  255. }
  256. //定时器0中断服务程序
  257. void Timer0() interrupt 1
  258. {
  259. static unsigned char i;
  260. static bit j;
  261. if(j)
  262. {
  263. j = 0;
  264. i++;
  265. if(i>g_myPar[6])
  266. {
  267. i = 0;
  268. CTRL_UP = 1;
  269. CTRL_DOWN = 0;
  270. TH0 = g_myPar[4];
  271. TL0 = g_myPar[5];
  272. }
  273. else
  274. {
  275. CTRL_UP = 1;
  276. CTRL_DOWN = 1;
  277. TH0 = g_myPar[2];
  278. TL0 = g_myPar[3];
  279. }
  280. }
  281. else
  282. {
  283. j = 1;
  284. CTRL_UP = 0;
  285. CTRL_DOWN = 1;
  286. TH0 = g_myPar[0];
  287. TL0 = g_myPar[1];
  288. }
  289. }
  290. //定时器1中断服务程序
  291. void Timer1() interrupt 3
  292. {
  293. static unsigned char i,j;
  294. unsigned char temp_data[2];
  295. unsigned char presence,k;
  296. TH1 = (65536 - 60730) / 256;
  297. TL1 = (65536 - 60730) % 256;
  298. i++;
  299. if(i>24)//时间显示
  300. {
  301. i=0;
  302. g_time[5]++;
  303. g_myPar[14]++;
  304. if(g_time[5] > 0x39)//秒个位
  305. {
  306. g_time[5] = 0x30;
  307. g_time[4]++;
  308. if(g_time[4] > 0x35)//秒十位
  309. {
  310. g_time[4] = 0x30;
  311. g_time[3]++;
  312. g_myPar[14] = 0;
  313. g_myPar[13]++;
  314. if(g_time[3] > 0x39)//分个位
  315. {
  316. g_time[3] = 0x30;
  317. g_time[2]++;
  318. if(g_time[2] > 0x35)//分十位
  319. {
  320. g_time[2] = 0x30;
  321. g_time[1]++;
  322. g_myPar[13] = 0;
  323. g_myPar[12]++;
  324. if(g_time[1] > 0x33)//时个位
  325. {
  326. g_time[1] = 0x30;
  327. g_time[0]++;
  328. if(g_time[0] > 0x39)//时十位
  329. {
  330. g_time[0] = 0x30;
  331. g_myPar[12]=0;
  332. }//时十位
  333. }//时个位
  334. WriteLCD(0,0x98+4);
  335. WriteLCD(1,g_time[0]);
  336. WriteLCD(1,g_time[1]);
  337. }//分十位
  338. WriteLCD(0,0x98+5);
  339. WriteLCD(1,:);
  340. WriteLCD(1,g_time[2]);
  341. }//分个位
  342. WriteLCD(0,0x98+6);
  343. WriteLCD(1,g_time[3]);
  344. }//秒十位
  345. }//秒个位
  346. WriteLCD(0,0x98+7);
  347. WriteLCD(1,g_time[4]);
  348. WriteLCD(1,g_time[5]);
  349. //显示充/放电状态
  350. j++;
  351. switch(j)
  352. {
  353. case 1:
  354. WriteLCD(0,0x98+2);
  355. WriteLCD(1, );
  356. WriteLCD(1, );
  357. WriteLCD(1, );
  358. StartADC();
  359. break;
  360. case 2:
  361. WriteLCD(0,0x98+2);
  362. WriteLCD(1,.);
  363. break;
  364. case 3:
  365. WriteLCD(0,0x98+2);
  366. WriteLCD(1,.);
  367. WriteLCD(1,.);
  368. break;
  369. case 4:
  370. WriteLCD(0,0x98+3);
  371. WriteLCD(1,.);
  372. j = 0;
  373. break;
  374. default:
  375. j = 0;
  376. }
  377. presence = Init_DS18B20();
  378. if(presence==0)
  379. {
  380. WriteOneChar(0xCC); //跳过ROM匹配操作
  381. Delay4us(10);
  382. WriteOneChar(0x44); //启动温度转换
  383. }
  384. presence = Init_DS18B20();
  385. if(presence==0)
  386. {
  387. WriteOneChar(0xCC); //跳过ROM匹配操作
  388. Delay4us(10);
  389. WriteOneChar(0xBE); //读取温度寄存器
  390. Delay4us(10);
  391. temp_data[0] = ReadOneChar(); //温度低8位
  392. Delay4us(10);
  393. temp_data[1] = ReadOneChar(); //温度高8位
  394. if(presence==0)
  395. {
  396. if(temp_data[1]==0xff) presence=1;
  397. }
  398. }
  399. if(g_CurIn == 5)
  400. {
  401. for(k=0;k<5;k++)
  402. {
  403. g_myPar[7+k] = Reverse(g_myPar[7+k]);
  404. }
  405. g_Percent = g_myPar[7+2]*1.56-48;//(U1f-4.8)/10*100
  406. if(g_Percent>100) g_Percent = 0;
  407. if(CutState==0)//充电模式
  408. {
  409. g_tt10 = (65536-5*(105-g_Percent))/256;
  410. g_tt11 = (65536-5*(105-g_Percent))%256;
  411. g_tt20 = (65536-5*(5+g_Percent))/256;
  412. g_tt21 = (65536-5*(5+g_Percent))%256;
  413. g_myPar[0]=g_tt10;
  414. g_myPar[1]=g_tt11;
  415. g_myPar[2]=g_tt20;
  416. g_myPar[3]=g_tt21;
  417. g_myPar[4]=g_tt10;
  418. g_myPar[5]=g_tt11;
  419. }
  420. SqrtDuty = sqrt(1-g_Percent/100.0);
  421. //Duty=g_myPar[0]*100/(g_myPar[0]+g_myPar[1]);
  422. g_CurIn = 0;
  423. }
  424. if(CutState==2)//维护
  425. {
  426. WriteLCD(0,0x90);
  427. DspNumber(g_myPar[7+2]*156);//电池电压
  428. WriteLCD(1,V);
  429. //g_Percent = g_myPar[4+2]*1.56-48;
  430. DspPercent(g_Percent);
  431. if(presence==0)
  432. {
  433. WriteLCD(0,0x90+5);
  434. DspTemp(temp_data[1],temp_data[0]);
  435. }
  436. }
  437. else if(CutState==1)//放电
  438. {
  439. //显示参数g_U0,g_U1p,g_U1f,g_U2,g_U3,
  440. WriteLCD(0,0x90);
  441. DspNumber(g_myPar[7+2]*156);//电池电压
  442. WriteLCD(1,V);
  443. //g_Percent = g_myPar[4+2]*1.56-48;
  444. DspPercent(g_Percent);
  445. WriteLCD(0,0x88+4);
  446. WriteLCD(1,:);
  447. DspNumber((g_myPar[7+2]-g_myPar[7])*31);//放电电流
  448. if(presence==0)
  449. {
  450. WriteLCD(0,0x90+5);
  451. DspTemp(temp_data[1],temp_data[0]);
  452. }
  453. }
  454. else//充电
  455. {
  456. //显示参数g_U0,g_U1p,g_U1f,g_U2,g_U3,
  457. WriteLCD(0,0x80);
  458. DspNumber(g_myPar[7+2]*156);//电池电压
  459. WriteLCD(1,V);
  460. //g_Percent = g_myPar[4+2]*1.56-48;
  461. DspPercent(g_Percent);
  462. WriteLCD(0,0x90+4);
  463. WriteLCD(1,:);
  464. DspNumber(((g_myPar[7+4]-g_myPar[7+3])*78)*SqrtDuty);//充电电流
  465. WriteLCD(0,0x88+4);
  466. WriteLCD(1,:);
  467. DspNumber(g_myPar[7+4]*156*SqrtDuty);//充电电压
  468. if(presence==0)
  469. {
  470. WriteLCD(0,0x80+5);
  471. DspTemp(temp_data[1],temp_data[0]);
  472. }
  473. }
  474. }
  475. }
  476. //串口中断服务程序
  477. void Serial() interrupt 4
  478. {
  479. if(RI)
  480. {
  481. RI = 0;
  482. bSerialSending = 0;
  483. if(SBUF == 5)
  484. {
  485. SBUF = 6;
  486. }
  487. else if(SBUF == 6)
  488. {
  489. SendSerialData();
  490. }
  491. else
  492. {
  493. SBUF = 0xff;
  494. }
  495. }
  496. else
  497. {
  498. TI = 0;
  499. if(bSerialSending)
  500. {
  501. if(g_CurSend<15)
  502. {
  503. SBUF = g_myPar[g_CurSend];
  504. g_CurSend++;
  505. }
  506. else
  507. {
  508. bSerialSending = 0;
  509. }
  510. }
  511. }
  512. }
复制代码
18B20程序:
  1. #include <DS18B20.h>
  2. //unsigned char data temp_data[2];
  3. //DS18B20初始化
  4. unsigned char Init_DS18B20(void)
  5. {
  6. bit presence;
  7. DQ = 0; //单片机发出低电平复位信号
  8. Delay4us(120); //延时>480us
  9. DQ = 1; //释放数据线
  10. Delay4us(16); //延时>64us,等待应答
  11. presence = DQ; //接收应答信号
  12. Delay4us(100); //延时>400us,等待数据线出现高电平
  13. DQ = 1; //释放数据线
  14. return (presence); //返回presence信号
  15. }
  16. //读一个字节数据
  17. unsigned char ReadOneChar(void)
  18. {
  19. unsigned char i = 0;
  20. unsigned char dat = 0;
  21. DQ = 1;
  22. for (i = 0; i < 8; i++)
  23. //一个字节8个bit
  24. {
  25. DQ = 0; //给低脉冲信号
  26. dat >>= 1;
  27. DQ = 1; //释放总线
  28. _nop_();
  29. _nop_();
  30. if (DQ)
  31. //读总线电平状态
  32. dat |= 0x80;
  33. //最高位置1
  34. Delay4us(15); //延时>45us
  35. DQ = 1; //释放总线,表示此次读操作完成
  36. }
  37. return (dat); //返回所读得数据
  38. }
  39. //写一个字节数据
  40. void WriteOneChar(unsigned char dat)
  41. {
  42. unsigned char i = 0;
  43. for (i = 0; i < 8; i++)
  44. //一个字节8个bit
  45. {
  46. DQ = 0; //给低脉冲信号
  47. Delay4us(1); //延时<15us
  48. dat >>= 1; //数据右移一位,最低位移入CY
  49. DQ = CY; //写1bit数据
  50. Delay4us(15); //延时>45us
  51. DQ = 1; //释放总线,表示此次写操作完成
  52. }
  53. }
  54. /*//温度数据转换子程序
  55. void Temperature_conver()
  56. {
  57. unsigned char minus = 0;
  58. if (temp_data[1] > 127)
  59. //温度为负值
  60. {
  61. temp_data[0] = (~temp_data[0]) + 1; //取反加一,将补码变成原码
  62. if ((~temp_data[0]) >= 0xff)
  63. temp_data[1] = (~temp_data[1]) + 1;
  64. else
  65. temp_data[1] = ~temp_data[1];
  66. minus = 1; //温度为负值标志
  67. }
  68. }*/
复制代码
LCD12864程序:
  1. #include <lcd12864.h>//lcd12864相关控制
  2. unsigned char code date[3][64]={" 0.000V  0%  0.0"
  3. "充电电流: 0.000A"
  4. "充电电压: 0.000V"
  5. "充电... 00:00:00",
  6. "正在测试电池性能"
  7. " 0.000V  0%  0.0"
  8. "放电电流: 0.000A"
  9. "放电... 00:00:00",
  10. "正在维护电池    "
  11. " 0.000V  0%  0.0"
  12. "电池健康度   0% "
  13. "维护... 00:00:00"};
  14. //毫秒延时
  15. void Delay4us(unsigned char us)
  16. {
  17. while(us--);
  18. }
  19. //毫秒延时
  20. void DelayMs(unsigned int ms)
  21. {
  22. unsigned char i;
  23. while(ms--)
  24. {
  25. for(i=228; i>0; i--);
  26. }
  27. }
  28. //初始化LCD显示
  29. void InitLCDshow(unsigned char n)
  30. {
  31. unsigned char i;
  32. WriteLCD(0,0x80); for(i=0;i<16;i++)  WriteLCD(1,date[n][i]);
  33. WriteLCD(0,0x90); for(i=0;i<16;i++)  WriteLCD(1,date[n][i+16]);
  34. WriteLCD(0,0x88); for(i=0;i<16;i++)  WriteLCD(1,date[n][i+32]);
  35. WriteLCD(0,0x98); for(i=0;i<16;i++)  WriteLCD(1,date[n][i+48]);
  36. }
  37. //发送一个字节
  38. void SendByteLCD(unsigned char bbyte)
  39. {
  40. unsigned char i;
  41. for(i=0;i<8;i++)
  42. {
  43. SID=bbyte&0x80; //取出最高位
  44. SCLK=1;
  45. SCLK=0;
  46. bbyte<<=1; //左移
  47. }
  48. }
  49. //写指令或数据
  50. //#pragma disable
  51. void WriteLCD(unsigned char cmd, unsigned char num)//reentrant
  52. {
  53. if(cmd==0)
  54. {
  55. //start_num=0xf8;  //写指令
  56. SendByteLCD(0xf8);     //发送起始信号
  57. }
  58. else
  59. {
  60. //start_num=0xfa;  //写数据
  61. SendByteLCD(0xfa);     //发送起始信号
  62. }
  63. DelayMs(5);                        //延时是必须的
  64. SendByteLCD(num & 0xf0);        //发送高四位
  65. DelayMs(1);                        //延时是必须的
  66. SendByteLCD((num<<4) & 0xf0);              //发送低四位
  67. DelayMs(1);                        //延时是必须的
  68. }
  69. //显示一个数
  70. void DspNumber(unsigned int num)
  71. {
  72. unsigned char i,dsp[5];
  73. for(i=0;i<4;i++)
  74. {
  75. dsp[i] = num % 10;
  76. dsp[i] += 0x30;
  77. num /= 10;
  78. }
  79. if(num)
  80. {
  81. dsp[4] = num + 0x30;
  82. }
  83. else
  84. {
  85. dsp[4] = ;
  86. }
  87. WriteLCD(1,dsp[4]);
  88. WriteLCD(1,dsp[3]);
  89. WriteLCD(1,.);
  90. WriteLCD(1,dsp[2]);
  91. WriteLCD(1,dsp[1]);
  92. WriteLCD(1,dsp[0]);
  93. }
  94. void DspPercent(unsigned char per)
  95. {
  96. unsigned char i;
  97. i = per / 100;
  98. per %= 100;
  99. i += 0x30;
  100. if(i==)i= ;
  101. WriteLCD(1,i);
  102. i = per / 10;
  103. per %= 10;
  104. i += 0x30;
  105. if(i==)i= ;
  106. WriteLCD(1,i);
  107. per += 0x30;
  108. WriteLCD(1,per);
  109. }
  110. //显示温度
  111. void DspTemp(unsigned char num1,unsigned char num2)
  112. {
  113. unsigned char i;
  114. num1 = num1<<4 | num2>>4;
  115. num2 &= 0x0f;
  116. num2 /= 1.6;
  117. i = num1 / 100;
  118. num1 %= 100;
  119. WriteLCD(1, \%);
  120. if(i)
  121. {
  122. WriteLCD(1, i+0x30);
  123. i = num1 / 10;
  124. num1 %= 10;
  125. WriteLCD(1, i+0x30);
  126. WriteLCD(1, num1+0x30);
  127. }
  128. else
  129. {
  130. WriteLCD(1, );
  131. i = num1 / 10;
  132. num1 %= 10;
  133. if(i)
  134. {
  135. WriteLCD(1, i+0x30);
  136. }
  137. else
  138. {
  139. WriteLCD(1, );
  140. }
  141. WriteLCD(1, num1+0x30);
  142. }
  143. WriteLCD(1, .);
  144. WriteLCD(1, num2+0x30);
  145. /*    i = (num >> 4) + 0x30;
  146. if(i>9)i+=7;
  147. WriteLCD(1, i);
  148. i = (num & 0x0f) + 0x30;
  149. if(i>9)i+=7;
  150. WriteLCD(1,i);*/
  151. }
  152. //初始化LCD
  153. void InitLCD(void)
  154. {
  155. //PSB=0; ;     //串口驱动模式
  156. DelayMs(10); //启动等待,等LCM讲入工作状态
  157. RESET=0; DelayMs(1); RESET=1; // 复位LCD
  158. CS=1;
  159. WriteLCD(0,0x30);  //8 位介面,基本指令集
  160. WriteLCD(0,0x0c);  //显示打开,光标关,反白关
  161. WriteLCD(0,0x01);  //清屏,将DDRAM的地址计数器归零
  162. }
复制代码
发表于 2013-4-9 18:02 | 显示全部楼层
占位 慢慢看、、、
发表于 2013-4-9 20:16 | 显示全部楼层
好东西,下来学习学习
发表于 2013-4-10 07:56 | 显示全部楼层
像12V铅酸电池脉冲充电器,还带负脉冲放电!
发表于 2013-4-10 08:11 | 显示全部楼层
你这个是畜电池的,我这个是锂电池的,差远了!
发表于 2013-5-4 22:48 | 显示全部楼层
楼主这个程序能不能打个包啊。。复制有乱码
发表于 2013-5-5 08:22 | 显示全部楼层
程序是应该打个包。。。。。我手机上的看起来全是乱码。
发表于 2013-5-21 19:25 | 显示全部楼层
mark
发表于 2013-6-15 11:40 | 显示全部楼层
非常感谢楼主的分享!
发表于 2013-6-18 14:24 | 显示全部楼层
屌一乐 既然共享还不与人方便。什么玩意!
GMT+8, 2024-5-7 13:37 , Processed in 0.066084 second(s), 37 queries , Gzip On.
