版主
帖子
积分10609
阅读权限200
注册时间2008-11-22
操作系统:ubuntu10.04 R$ W- t5 ?! N& s$ v% p
* ]. x& r9 @2 v: H' F
. f8 c9 O4 `3 a6 B- h9 [! L前言:
" {9 {/ x' O, R/ J$ C' R 要完成自己的uboot,首先要熟悉广泛使用的Uboot的架构,实现。; o3 T: M8 m- p
而看linux的大项目的源码,切入点基本都是从makefile开始。; R1 F$ }5 G3 X1 h+ O5 a+ f( {
( {6 M3 m! D% }$ ~; P, r. F
1,makefile详解:4 L: R- ^2 @7 \; ^' \
如果对makefile有疑惑的请看:*makefile 博文链接
* O" U& [! @) e* v. q( r. t点击(此处)折叠或打开 : k7 N$ P; h5 U
- (C) Copyright 2000-2006
9 e) N9 `# p$ X# H* ^+ j - # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- # See file CREDITS for list of people who contributed to this
- # project.
- # This program is free software; you can redistribute it and/or
- # modify it under the terms of the GNU General Public License as
- # published by the Free Software Foundatio; either version 2 of
- # the License, or (at your option) any later version.
- # This program is distributed in the hope that it will be useful,
- # but WITHOUT ANY WARRANTY; without even the implied warranty of
- # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- # GNU General Public License for more details.
- # You should have received a copy of the GNU General Public License
- # along with this program; if not, write to the Free Software
- # Foundation, Inc., 59 Temple Place, Suite 330, Boston,
- # MA 02111-1307 USA
- VERSION = 1
- PATCHLEVEL = 1
- SUBLEVEL = 6
- EXTRAVERSION =
- U_BOOT_VERSION = $(VERSION).$(PATCHLEVEL).$(SUBLEVEL)$(EXTRAVERSION)
- VERSION_FILE = $(obj)include/version_autogenerated.h
- #@定义主机系统架构@:
- # “sed –e”表示后面跟的是一串命令脚本,而表达式“s/abc/def/”表示要从标准输入中,
- # 查找到内容为“abc”的,然后替换成“def”。其中“abc”表达式用可以使用“.”作为通配符。
- # 命令“uname –m”将输出主机CPU的体系架构类型。作者的电脑使用Intel Core2系列的CPU,
- # 因此“uname –m”输出“i686”。 “i686”可以匹配命令“sed -e s/i.86/i386/”中的“i.86”,
- # 因此在作者的机器上执行Makefile,HOSTARCH 将被设置成“i386” 。
- HOSTARCH := $(shell uname -m | \
- sed -e s/i.86/i386/ \
- -e s/sun4u/sparc64/ \
- -e s/ARM.*/arm/ \
- -e s/sa110/arm/ \
- -e s/powerpc/ppc/ \
- -e s/macppc/ppc/)
- #@定义主机操作系统类型@:
- # “uname –s”输出主机内核名字,作者使用Linux发行版Ubuntu11.10,因此“uname –s”结果是“Linux”。
- # “tr '[:upper:]' '[:lower:]'”作用是将标准输入中的所有大写字母转换为响应的小写字母。
- # 因此执行结果是将HOSTOS 设置为“linux”。
- HOSTOS := $(shell uname -s | tr '[:upper:]' '[:lower:]' | \
- sed -e 's/\(cygwin\).*/cygwin/')
- #导出变量HOSTARCH HOSTOS SHELL,使别的文件可以使用这些变量
- export HOSTARCH HOSTOS
- # Deal with colliding definitions from tcsh etc.
- VENDOR=
- # U-boot build supports producing a object files to the separate external
- # directory. Two use cases are supported:
- # 1) Add O= to the make command line
- # 'make O=/tmp/build all'
- # 2) Set environement variable BUILD_DIR to point to the desired location
- # 'export BUILD_DIR=/tmp/build'
- # 'make'
- # The second approach can also be used with a MAKEALL script
- # './MAKEALL'
- # Command line 'O=' setting overrides BUILD_DIR environent variable.
- # When none of the above methods is used the local build is performed and
- # the object files are placed in the source directory.
- #@设定编译输出目录@:
- # 函数$( origin, variable) 输出的结果是一个字符串,输出结果由变量variable定义的方式决定,
- # 若variable在命令行中定义过,则origin函数返回值为"command line"。
- # 假若在命令行中执行了“export BUILD_DIR=/tmp/build”的命令,则“$(origin O)”值为“command line”,
- # 而BUILD_DIR被设置为“/tmp/build”。
- # 假若在命令行中执行了“make xx_config”的命令,则“$(origin O)”输出值不为为“command line”,
- # 故BUILD_DIR没有被操作。
- ifdef O
- ifeq ("$(origin O)", "command line")
- BUILD_DIR := $(O)
- endif
- endif
- #判断 BUILD_DIR 变量是否不为空,当前 BUILD_DIR 为 空,条件为假。
- ifneq ($(BUILD_DIR),)
- saved-output := $(BUILD_DIR)
- #若${BUILD_DIR}表示的目录没有被创建,则创建该目录。
- # Attempt to create a output directory.
- $(shell [ -d ${BUILD_DIR} || mkdir -p ${BUILD_DIR})
- #若$(BUILD_DIR)为创建失败或不存在,则将其赋值为当前目录路径(源代码目录)。
- #并检查$(BUILD_DIR)目录是否存在。
- #Pwd命令用以获取当前路径
- # Verify if it was successful.
- BUILD_DIR := $(shell cd $(BUILD_DIR) && /bin/pwd)
- $(if $(BUILD_DIR),,$(error output directory "$(saved-output)" does not exist))
- endif # ifneq ($(BUILD_DIR),)
- #CURDIR变量指示Make当前的工作目录,由于当前Make在U-Boot顶层目录执行Makefile,
- #因此CURDIR此时就是U-Boot顶层目录。
- #执行完上面的代码后, SRCTREE,src变量就是U-Boot代码顶层目录,而OBJTREE,obj变量就是输出目录,
- #若没有定义BUILD_DIR环境变量,则SRCTREE,src变量与OBJTREE,obj变量都是U-Boot源代码目录。
- #而MKCONFIG则表示U-Boot根目录下的mkconfig脚本。
- #if函数计算OBJTREE的值,如果BUILD_DIR不为空,if函数的值就是BUILD_DIR,否则是CURDIR.
- #CURDIR是个环境变量。代表当前文件的目录,即uboot根目录,设为 : ./。
- # CURDIR = ./
- # OBJTREE = ./
- # SPLTREE = ./spl
- # SRCTREE = ./
- # TOPDIR = ./
- # LNDIR = ./
- #导出变量TOPDIR SRCTREE OBJTREE SPLTREE,使别的文件可以使用这些变量
- OBJTREE := $(if $(BUILD_DIR),$(BUILD_DIR),$(CURDIR))
- SRCTREE := $(CURDIR)
- TOPDIR := $(SRCTREE)
- LNDIR := $(OBJTREE)
- export TOPDIR SRCTREE OBJTREE
- # MKCONFIG = ./mkconfig
- #导出变量MKCONFIG
- MKCONFIG := $(SRCTREE)/mkconfig
- export MKCONFIG
- #判断变量OBJTREE 与 SRCTREE 是否不相等,OBJTREE为./,SRCTREE为./,条件为假。
- ifneq ($(OBJTREE),$(SRCTREE))
- REMOTE_BUILD := 1
- export REMOTE_BUILD
- endif
- #则 obj 为 空
- # src 为 空
- #导出变量 obj src
- # $(obj) and (src) are defined in config.mk but here in main Makefile
- # we also need them before config.mk is included which is the case for
- # some targets like unconfig, clean, clobber, distclean, etc.
- obj := $(OBJTREE)/
- src := $(SRCTREE)/
- else
- obj :=
- src :=
- endif
- export obj src
- #使用“$(wildcard *.c) ”来获取工作目录下的所有的.c 文件列表
- #在当前例子中,则是为了找到 ./include/config.mk
- #判断是否找到 ./include/config.mk
- ifeq ($(OBJTREE)/include/config.mk,$(wildcard $(OBJTREE)/include/config.mk))
- #包含 ./include/config.mk
- # ARCH = arm
- # CPU = arm920t
- # BOARD = 100ask24x0
- # VENDOR =
- # SOC = s3c24x0
- # load ARCH, BOARD, and CPU configuration
- include $(OBJTREE)/include/config.mk
- export ARCH CPU BOARD VENDOR SOC
- #若主机架构与开发板结构相同,就使用主机的编译器,而不是交叉编译器
- #当前 HOSTARCH 为 i386
- #当前 ARCH 为 arm
- #条件为假,则 CROSS_COMPILE 为交叉编译器,即 CROSS_COMPILE = arm-linux-
- ifndef CROSS_COMPILE
- ifeq ($(HOSTARCH),ppc)
- CROSS_COMPILE =
- else
- ifeq ($(ARCH),ppc)
- CROSS_COMPILE = powerpc-linux-
- endif
- ifeq ($(ARCH),arm)
- CROSS_COMPILE = arm-linux-
- endif
- ifeq ($(ARCH),i386)
- ifeq ($(HOSTARCH),i386)
- CROSS_COMPILE =
- else
- CROSS_COMPILE = i386-linux-
- endif
- endif
- ifeq ($(ARCH),mips)
- CROSS_COMPILE = mips_4KC-
- endif
- ifeq ($(ARCH),nios)
- CROSS_COMPILE = nios-elf-
- endif
- ifeq ($(ARCH),nios2)
- CROSS_COMPILE = nios2-elf-
- endif
- ifeq ($(ARCH),m68k)
- CROSS_COMPILE = m68k-elf-
- endif
- ifeq ($(ARCH),microblaze)
- CROSS_COMPILE = mb-
- endif
- ifeq ($(ARCH),blackfin)
- CROSS_COMPILE = bfin-elf-
- endif
- ifeq ($(ARCH),AVR32)
- CROSS_COMPILE = AVR32-
- endif
- endif
- #($(HOSTARCH),ppc)
- endif
- #ifndef CROSS_COMPILE
- export CROSS_COMPILE
- #包含 ./config.mk 文件,其主要是一些变量和函数的定义,编译链接的参数设置以及依赖规则.
- # load other configuration
- include $(TOPDIR)/config.mk
- # U-Boot objects....order is important (i.e. start must be first)
- #OBJS = cpu/arm920t/start.o
- OBJS = cpu/$(CPU)/start.o
- ifeq ($(CPU),i386)
- OBJS += cpu/$(CPU)/start16.o
- OBJS += cpu/$(CPU)/reset.o
- endif
- ifeq ($(CPU),ppc4xx)
- OBJS += cpu/$(CPU)/resetvec.o
- endif
- ifeq ($(CPU),mpc83xx)
- endif
- ifeq ($(CPU),mpc85xx)
- endif
- ifeq ($(CPU),mpc86xx)
- endif
- ifeq ($(CPU),bf533)
- OBJS += cpu/$(CPU)/start1.o cpu/$(CPU)/interrupt.o cpu/$(CPU)/cache.o
- OBJS += cpu/$(CPU)/cplbhdlr.o cpu/$(CPU)/cplbmgr.o cpu/$(CPU)/flush.o
- endif
- #加前缀,如
- #$(addprefix src/,foo bar)
- #结果:src/foo src/bar
- #当前 obj :=
- #OBJS := cpu/arm920t/start.o
- OBJS := $(addprefix $(obj),$(OBJS))
- LIBS = lib_generic/libgeneric.a
- LIBS += board/$(BOARDDIR)/lib$(BOARD).a
- LIBS += cpu/$(CPU)/lib$(CPU).a
- ifdef SOC
- LIBS += cpu/$(CPU)/$(SOC)/lib$(SOC).a
- endif
- LIBS += lib_$(ARCH)/lib$(ARCH).a
- LIBS += fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a \
- fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a
- LIBS += net/libnet.a
- LIBS += disk/libdisk.a
- LIBS += rtc/librtc.a
- LIBS += dtt/libdtt.a
- LIBS += drivers/libdrivers.a
- LIBS += drivers/nand/libnand.a
- LIBS += drivers/nand_legacy/libnand_legacy.a
- LIBS += drivers/sk98lin/libsk98lin.a
- LIBS += post/libpost.a post/cpu/libcpu.a
- LIBS += common/libcommon.a
- LIBS += $(BOARDLIBS)
- LIBS := $(addprefix $(obj),$(LIBS))
- .PHONY : $(LIBS)
- #确保可以对LIBS进行操作
- # Add GCC lib
- PLATFORM_LIBS += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc
- # The "tools" are needed early, so put this first
- # Don't include stuff already done in $(LIBS)
& H& M% b8 a Q* N. {0 P5 r3 {9 J1 p* R$ N - SUBDIRS = tools \
- examples \
- post \
- post/cpu
- .PHONY : $(SUBDIRS)
- #如果CONFIG_NAND_U_BOOT变量是否等于 y,当前没有定义CONFIG_NAND_U_BOOT变量,条件为假。
- #则不执行条件中的代码
- ifeq ($(CONFIG_NAND_U_BOOT),y)
- NAND_SPL = nand_spl
- U_BOOT_NAND = $(obj)u-boot-nand.bin
- endif
- #如果对 makefile中subst 函数有疑问的请看:http://blog.chinaunix.net/uid-28458801-id-4080763.html
- #__OBJS := cpu/arm920t/start.o
- #__LIBS := lib_generic/libgeneric.a board/100ask24x0/lib100ask24x0.a
- # cpu/arm920t/libarm920t.a cpu/arm920t/s3c24x0/libs3c24x0.a lib_arm/libarm.a
- # fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a
- # net/libnet.a disk/libdisk.a rtc/librtc.a dtt/libdtt.a
- # drivers/libdrivers.a drivers/nand/libnand.a drivers/nand_legacy/libnand_legacy.a drivers/usb/libusb.a drivers/sk98lin/libsk98lin.a
- # common/libcommon.a
- __OBJS := $(subst $(obj),,$(OBJS))
- __LIBS := $(subst $(obj),,$(LIBS))
- ALL = $(obj)u-boot.srec $(obj)u-boot.bin $(obj)System.map $(U_BOOT_NAND)
- all: $(ALL)
- $(obj)u-boot.hex: $(obj)u-boot
- $(OBJCOPY) ${OBJCFLAGS} -O ihex $< $@
- $(obj)u-boot.srec: $(obj)u-boot
- $(OBJCOPY) ${OBJCFLAGS} -O srec $< $@
- $(obj)u-boot.bin: $(obj)u-boot
- $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@
- $(obj)u-boot.img: $(obj)u-boot.bin
- ./tools/mkimage -A $(ARCH) -T firmware -C none \
- -a $(TEXT_BASE) -e 0 \
- -n $(shell sed -n -e 's/.*U_BOOT_VERSION//p' $(VERSION_FILE) | \
- sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \
- -d $< $@
- $(obj)u-boot.dis: $(obj)u-boot
- $(OBJDUMP) -d $< > $@
- $(obj)u-boot: depend version $(SUBDIRS) $(OBJS) $(LIBS) $(LDSCRIPT)
- UNDEF_SYM=`$(OBJDUMP) -x $(LIBS) |sed -n -e 's/.*\(__u_boot_cmd_.*\)/-u\1/p'|sort|uniq`;\
- cd $(LNDIR) && $(LD) $(LDFLAGS) $$UNDEF_SYM $(__OBJS) \
- --start-group $(__LIBS) --end-group $(PLATFORM_LIBS) \
- -Map u-boot.map -o u-boot
- $(OBJS):
- $(MAKE) -C cpu/$(CPU) $(if $(REMOTE_BUILD),$@,$(notdir $@))
- $(LIBS):
- $(MAKE) -C $(dir $(subst $(obj),,$@))
- $(SUBDIRS):
- $(MAKE) -C $@ all
- $(NAND_SPL): version
- $(MAKE) -C nand_spl/board/$(BOARDDIR) all6 Q8 e, k2 x7 i/ Z
& y3 V& s) r8 K! c5 J) B. N6 r# Y& h' U( Y, f" t2 I- E$ T
) U: h# O+ w5 Y3 S* k
' G3 ], O- H/ d6 r8 T
- A0 x4 e; `# g8 X: o/ T2 m8 [3 o5 @; g6 i# {- C5 A% p( K
& P7 }. g, s* C" x( O# V
